[QGIS-Developer] build fails SOLVED
Donald Harter
harterc2 at att.net
Thu Jul 5 02:56:34 PDT 2018
Yes I found that it is installed. I wasn't getting a match until I used
this pattern.
dpkg -l "libqt5serialport5"
Desired=Unknown/Install/Remove/Purge/Hold
Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version
Architecture Description
ii libqt5serialport5:amd64 5.9.5-0ubuntu1
amd64 Qt 5 serial port support
It is compiling now that I installed libqt5serialport5-dev which has the
.cmake files. I see that the required package list for bionic has been
updated.
On 07/05/2018 01:46 AM, Patrick Dunford wrote:
> There are packages for bionic if that is what you are building on.
> On 05/07/18 13:03, Donald Harter wrote:
>> I fetched and pulled the latest source code for Qgis and it does not
>> build. Is there some sort of new dependency? My distribution does not
>> have such a package.
>> -- Qt WebKit support enabled
>> CMake Error at CMakeLists.txt:303 (FIND_PACKAGE):
>> By not providing "FindQt5SerialPort.cmake" in CMAKE_MODULE_PATH this
>> project has asked CMake to find a package configuration file
>> provided by
>> "Qt5SerialPort", but CMake did not find one.
>> Could not find a package configuration file provided by "Qt5SerialPort"
>> with any of the following names:
>> Qt5SerialPortConfig.cmake
>> qt5serialport-config.cmake
>> Add the installation prefix of "Qt5SerialPort" to CMAKE_PREFIX_PATH
>> or set
>> "Qt5SerialPort_DIR" to a directory containing one of the above
>> files. If
>> "Qt5SerialPort" provides a separate development package or SDK, be
>> sure it
>> has been installed.
>> -- Configuring incomplete, errors occurred!
>> Distributor ID: Ubuntu
>> Description: Ubuntu 18.04 LTS
>> Release: 18.04
>> Codename: bionic
>> git branch
>> * master
>> release-3_0
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
