[QGIS-Developer] build fails SOLVED
Patrick Dunford
enzedrailmaps at gmail.com
Thu Jul 5 04:16:47 PDT 2018
Sorry I was unclear if you were referring to the Qt package being
unable, or complete packages for bionic full install of Qgis.
On 05/07/18 21:56, Donald Harter wrote:
> Yes I found that it is installed. I wasn't getting a match until I
> used this pattern.
> dpkg -l "libqt5serialport5"
> Desired=Unknown/Install/Remove/Purge/Hold
> Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
> |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
> ||/ Name Version
> Architecture Description
> ii libqt5serialport5:amd64 5.9.5-0ubuntu1
> amd64 Qt 5 serial port support
> It is compiling now that I installed libqt5serialport5-dev which has
> the .cmake files. I see that the required package list for bionic
> has been updated.
> On 07/05/2018 01:46 AM, Patrick Dunford wrote:
>> There are packages for bionic if that is what you are building on.
>> On 05/07/18 13:03, Donald Harter wrote:
>>> I fetched and pulled the latest source code for Qgis and it does not
>>> build. Is there some sort of new dependency? My distribution does
>>> not have such a package.
>>> -- Qt WebKit support enabled
>>> CMake Error at CMakeLists.txt:303 (FIND_PACKAGE):
>>> By not providing "FindQt5SerialPort.cmake" in CMAKE_MODULE_PATH this
>>> project has asked CMake to find a package configuration file
>>> provided by
>>> "Qt5SerialPort", but CMake did not find one.
>>> Could not find a package configuration file provided by
>>> "Qt5SerialPort"
>>> with any of the following names:
>>> Qt5SerialPortConfig.cmake
>>> qt5serialport-config.cmake
>>> Add the installation prefix of "Qt5SerialPort" to
>>> CMAKE_PREFIX_PATH or set
>>> "Qt5SerialPort_DIR" to a directory containing one of the above
>>> files. If
>>> "Qt5SerialPort" provides a separate development package or SDK, be
>>> sure it
>>> has been installed.
>>> -- Configuring incomplete, errors occurred!
>>> Distributor ID: Ubuntu
>>> Description: Ubuntu 18.04 LTS
>>> Release: 18.04
>>> Codename: bionic
>>> git branch
>>> * master
>>> release-3_0
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
