[QGIS-Developer] about geopackage filter and identify object in QGIS 3.2
Richard Duivenvoorde rdmailings at duif.net
Fri Jul 6 06:46:27 PDT 2018
Hi Olcay,
Maybe you can add a small test dataset and project to the issue?
So it is easier for dev's to (re)test?
It also adds 'weight' to an issue if others also have this problem (aka
it can be reproducibly confirmed).
Thanks
Regards,
On 07/06/2018 02:52 PM, Olcay Ebcin wrote:
>     My problem is listed in Bug report #19330
>     I’ve just seen it.
> *From:*Olcay Ebcin [mailto:olcay.ebcin at odakent.com.tr]
> *Sent:* Friday, July 6, 2018 3:42 PM
> *To:* 'qgis-developer at lists.osgeo.org' <qgis-developer at lists.osgeo.org>
> *Subject:* about geopackage filter and identify object in QGIS 3.2
> Hi,
> There is a problem only in GeoPackage layers.
> I have realized that when you put any expression in Provider feature
> filter (like “id” > 1), Layer is loaded successfully according to filter.
> On the other hand, identifying any feature on this layer, gives wrong
> results. There is a sequence shift.
> Without filter on the layer, identifying results are OK.
> In Girona version there is no problem.  This problem is occuring after
> Bonn version.
> Regards,
> Olcay Ebcin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
