[QGIS-Developer] Reading OSM data from .osm file
Etienne Trimaille
etienne.trimaille at gmail.com
Tue Jul 24 08:03:53 PDT 2018
For me, I have it in /usr/share/gdal/2.2/osmconf.ini
It's by default with gdal. Only a few columns should be created by default:
https://github.com/OSGeo/gdal/blob/master/gdal/data/osmconf.ini
<https://github.com/OSGeo/gdal/blob/master/gdal/data/osmconf.ini#L48>
http://www.gdal.org/drv_osm.html how to use this file.
2018-07-24 10:25 GMT-04:00 DelazJ <delazj at gmail.com>:
> Hi,
> Etienne, where does the osmconf file come from? Is it a default file in
> QGIS (v3) installation or something added when installing the QuickOSM
> plugin?
> I mean should the aforementioned option 4 have returned the data in a
> ""flat"" shape (a key <-> a field), as does QuickOSM by default?
> Thanks,
> Harrissou
> 2018-07-24 15:45 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
>> Hey,
>> > When you have your .osm file on your computer (eg downloaded from
>> > outside QGIS), you can open it with:
>> > * QuickOSM with the default parser, each keys will have their own
>> fields.
>> > * QuickOSM with your custom osmconf.ini file. The attribute table is
>> > defined according to your osmconf file.
>> > * OSM core importer in QGIS 2, not sure about the final attribute table.
>> > * QGIS, loading a normal vector file. The osmconf file on your computer
>> > will be used to define the attribute table.
>> > So it seems you are using the last option, right? So maybe you modified
>> > the default osmconf file?
>> it seems so. Never touched the osmconf file (almost a fresh Debian Sid
>> OS). It just seems strange to me that the "default" parser (the last one
>> of the list) is lossy (meaning that many columns can collapse into a
>> single not usable one).
>> Anyway: QuickOSM parser works like a charm ;)
>> Thanks to all
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180724/902247a7/attachment-0001.html>
