[QGIS-Developer] Reading OSM data from .osm file
DelazJ
delazj at gmail.com
Tue Jul 24 07:25:11 PDT 2018
Etienne, where does the osmconf file come from? Is it a default file in
QGIS (v3) installation or something added when installing the QuickOSM
plugin?
I mean should the aforementioned option 4 have returned the data in a
""flat"" shape (a key <-> a field), as does QuickOSM by default?
Thanks,
Harrissou
2018-07-24 15:45 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hey,
> > When you have your .osm file on your computer (eg downloaded from
> > outside QGIS), you can open it with:
> > * QuickOSM with the default parser, each keys will have their own fields.
> > * QuickOSM with your custom osmconf.ini file. The attribute table is
> > defined according to your osmconf file.
> > * OSM core importer in QGIS 2, not sure about the final attribute table.
> > * QGIS, loading a normal vector file. The osmconf file on your computer
> > will be used to define the attribute table.
> > So it seems you are using the last option, right? So maybe you modified
> > the default osmconf file?
> it seems so. Never touched the osmconf file (almost a fresh Debian Sid
> OS). It just seems strange to me that the "default" parser (the last one
> of the list) is lossy (meaning that many columns can collapse into a
> single not usable one).
> Anyway: QuickOSM parser works like a charm ;)
> Thanks to all
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180724/ff7e65fd/attachment.html>
