[QGIS-Developer] Update for QGIS testing manual
DelazJ delazj at gmail.com
Tue Jul 24 09:23:42 PDT 2018
Hi Calvin
2018-07-24 17:59 GMT+02:00 C Hamilton <adenaculture at gmail.com>:
> I was looking at the QGIS manual page
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/
> vectorcreation.html#qgiscreategrid
> It says that Create Grid is under Vector -> Analysis Tools. In the main
> menu it is really under Vector->Research Tools and under Processing it is
> under "Vector creation".
> Is it easy to get set up to make changes to the manual if I find errors
> like this?
> Sure. At the bottom of the page, you have a "*Textual error, missing text
or you know better: Fix Me*" message. Press the link and you are done: it
will directly bring you to the concerned page (it will also create the docs
repo if unavailable in your GitHub account - I assume you have one). Fix
the error and send a pull request.
More details at
https://docs.qgis.org/testing/en/docs/documentation_guidelines/first_contribution.html#alternative-2-using-the-fix-me-shortcut
Hope that helps,
Harrissou
Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180724/aed27389/attachment.html>
More information about the QGIS-Developer mailing list
