[QGIS-Developer] custom plugin repository in QGIS 3
Borys Jurgiel
lists at borysjurgiel.pl
Wed Jul 25 02:32:54 PDT 2018
Dnia środa, 25 lipca 2018 10:22:19 CEST Richard Duivenvoorde pisze:
> On 07/25/2018 10:00 AM, Denis Rouzaud wrote:
> > Hi all,
> > I have troubles at using a custom external plugin repository in QGIS 3.
> > The plugin installed and the plugin on the repo don't match in the
> > plugin manager. In other words, I cannot upgrade my plugin since it is
> > listed once in installed and once in not installed.
> > I wonder if anything changed in QGIS 3 that might have affected this.
Hmmm I don't remember any change than could cause this. Does the zip file
basename matches the directory name or do you use any suffixes?
> > There used to be some details listed in the manager in QGIS 2.x that are
> > not in 3:
> > installed version: (the local path)
> > available version: the plugin repo name (either QGIS or custom)
> > If anyone has a hint :)
> Well, I know that both the 'Installed version' and the 'Available
> version' numbers have a tooltip showing the local path and repo
> It is a little 'hidden' and Borys promissed to make it more prominent in
> the dialog :)
Yes, and it's approaching fast on my TODO queue :)
Borys
