[QGIS-Developer] custom plugin repository in QGIS 3
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Jul 25 03:38:36 PDT 2018
Thanks for your answers.
Le mer. 25 juil. 2018 à 11:33, Borys Jurgiel <lists at borysjurgiel.pl> a
écrit :
> Dnia środa, 25 lipca 2018 10:22:19 CEST Richard Duivenvoorde pisze:
> > On 07/25/2018 10:00 AM, Denis Rouzaud wrote:
> > > Hi all,
> > > I have troubles at using a custom external plugin repository in QGIS 3.
> > > The plugin installed and the plugin on the repo don't match in the
> > > plugin manager. In other words, I cannot upgrade my plugin since it is
> > > listed once in installed and once in not installed.
> > > I wonder if anything changed in QGIS 3 that might have affected this.
> Hmmm I don't remember any change than could cause this. Does the zip file
> basename matches the directory name or do you use any suffixes?
The zip file has a suffix with the version: pluginname-x.x.x.zip
Could it be the issue?
> > > There used to be some details listed in the manager in QGIS 2.x that
> are
> > > not in 3:
> > > installed version: (the local path)
> > > available version: the plugin repo name (either QGIS or custom)
> > > If anyone has a hint :)
> > Well, I know that both the 'Installed version' and the 'Available
> > version' numbers have a tooltip showing the local path and repo
> > It is a little 'hidden' and Borys promissed to make it more prominent in
> > the dialog :)
> Yes, and it's approaching fast on my TODO queue :)
> Borys
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180725/0cfd7871/attachment.html>
