[QGIS-Developer] Crash with QgsAuthManager() in 3.x
Luigi Pirelli
luipir at gmail.com
Mon Jun 4 07:06:01 PDT 2018
as far as I know/remember, nothing is changed from the AuthManager point of
view... only the sigleton has been moved as wrote by Nyall, as most of
singleton.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-
intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On 3 June 2018 at 07:27, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 03-06-18 01:14, Nyall Dawson wrote:
> > The docs need fixing here (I'll do that). You shouldn't be creating
> > your own auth manager, but instead use the manager returned by
> > auth_man = QgsApplication.authManager()
> > Nyall
> Ah, Thanks Nyall: works!! :-)
> About docs: I had a look into the pyqgis docs:
> https://qgis.org/pyqgis/master/core/Auth/QgsAuthManager.html
> But the code is very thin on comments/docs a thin code either:
> https://qgis.org/api/qgsauthmanager_8h_source.html
> https://qgis.org/api/qgsauthmanager_8cpp_source.html
> Is the plan to update the cookbook?
> https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookb
> ook/authentication.html
> Or do we prefer to update docs in code so it will show up in api docs?
> I can help with the cookbook, though I'm not very much up to date with
> specific changes, but I can at least check things there and writup what
> I do now.
> Regards & thanks again,
> Richard
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180604/35af1864/attachment.html>
