[QGIS-Developer] mirroring qgis.org repos
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Jun 5 04:53:09 PDT 2018
Hi Richard,
nocache.qgis.org did the trick for us
thank you for your effort
Bernhard
Am 05.06.2018 um 12:22 schrieb Richard Duivenvoorde:
> On 05-06-18 09:54, Richard Duivenvoorde wrote:
>> On 05-06-18 09:31, Jürgen E. Fischer wrote:
>>> Hi Bernhard,
>>> On Tue, 05. Jun 2018 at 08:29:09 +0200, Bernhard Ströbl wrote:
>>>> has anything changed recently? We have -again- since several days problems
>>>> mirroring ubuntugis locally:
>>>> debmirror --dist=xenial --section=main --arch=i386,amd64 --cleanup
>>>> --host=qgis.org --root=ubuntugis-ltr --method=https --rsync-extra=none
>>>> /mirrorpath
>>>> fails with 403 both via http and https
>>> Odd.  With wget and a browser I can get
>>> https://qgis.org/ubuntugis-ltr/dists/xenial/Release.
>>> But I can reproduce with debmirror.   I works when when I use nocache.qgis.org
>>> instead of qgis.org.
>>> Looks like a cloudflare issue.
>> Using myself here (adding -v -debug).
> Did some more testing, and it is definitly a cloudflare issue.
> If I disable caching on qgis.org temporarily it works.
> But if I use a silly (googled) perl script which mimics the perl lines
> from debmirror:
> # Create a user agent object
> use LWP::UserAgent;
> my $ua = LWP::UserAgent->new;
> my $res = $ua->mirror(
> 'https://anonymous@qgis.org/ubuntugis-ltr/dists/xenial/Release',
> '/tmp/Release' );
> # Check the outcome of the response
> if ($res->is_success) {
>      print $res->content;
> else {
>      print $res->status_line, "\n";
> it also(!) just works...
> Tried to set the ssl_verification to false, other headers, but I could
> not make debmirror work.
> We cannot remove cache from qgis.org (as we generate too much web
> traffic then, and our services really become slower)
> You could use https://nocache.qgis.org ?
> I prefer to keep ubuntu.qgis.org cached too, unless others have problems
> with it too..
> Sorry I cannot be of more help.
> Regards,
> Richard
> __________ Information from ESET Mail Security, version of virus signature database 17500 (20180605) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 17501 (20180605) __________
http://www.eset.com
More information about the QGIS-Developer mailing list
