[QGIS-Developer] Rectangles-Ovals-Digitizing plugin deprecated
Patrick Dunford
enzedrailmaps at gmail.com
Tue Jun 5 06:26:03 PDT 2018
I use it, but only when needing to actually draw, as it leaks memory
quite badly causing the software to slow down. The rest of the time I
start up Qgis (2.18) using the -noplugins flag to prevent it from loading.
I know there is some kind of capability in 3.0 included but I haven't
figured out how to use it.
On 05/06/18 23:51, Matthias Kuhn wrote:
> I have never used the plugin but repeatedly seen its name mentioned, so
> I assume it's widely used?
> In this case, it would be great if someone could volunteer as a new
> maintainer for the plugin. I think the minimal amount of work would be
> to merge pull requests and upload patched releases to the plugin repository.
> Regards
> Matthias
