[QGIS-Developer] QGIS server question: opacities of selection colors in a layer
Andreas Neumann
a.neumann at carto.net
Fri Jun 8 03:26:36 PDT 2018
I am refering to the SELECTION parameter in QGIS server, as described in
https://docs.qgis.org/2.18/en/docs/user_manual/working_with_ogc/server/services.html#getmap
- see section on "SELECTION"
I am trying to achieve a transparent selection, so that layers beneath
the selected layer can shine through. I thought that QGIS server would
pick up the selection color and opacity of the project - but apparently
this isn't the case. Is there a possibility to influence selection color
and opacity in QGIS server?
My tests were with QGIS server 2.18. Not sure if things have improved in
version 3 in this respect?
Thank you for your replies.
Andreas
