[QGIS-Developer] macOS build SIP error in master
Denis Rouzaud denis.rouzaud at gmail.com
Mon Jun 11 04:10:33 PDT 2018
Hi Tim,
Apparently, you're using the system Python. Are you sure you have sip
installed in there?
In my config, sip is installed in /usr/local/lib/python3.6/site-packages/
Denis
Le lun. 11 juin 2018 à 05:20, Tim Sutton <tim at kartoza.com> a écrit :
> Hi All (Larry?)
> Testing the latest master from today, self build on macOS, I am getting
> this on application start up (see below). Is this a Mac only problem? Does
> anyone else building on Mac Get this?
> Regards
> Tim
> Couldn't load SIP module.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
> ModuleNotFoundError: No module named 'sip'
> Python version:
> 3.6.4 (v3.6.4:d48ecebad5, Dec 18 2017, 21:07:28)
> [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
> QGIS version:
> 3.1.0-Master 'Master', 4e084b63c4
> Python path:
> ['/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python',
> '/Users/timlinux/Library/Application
> Support/QGIS/QGIS3/profiles/default/python',
> Support/QGIS/QGIS3/profiles/default/python/plugins',
> '/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins',
> '/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/bin/$PYTHONPATH',
> '/usr/local/opt/gdal2-python/lib/python3.6/site-packages',
> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip',
> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6',
> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload',
> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages’]
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Ex Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/0c89893f/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/0c89893f/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/0c89893f/attachment-0003.jpg>
More information about the QGIS-Developer mailing list
