[QGIS-Developer] macOS build SIP error in master
Tim Sutton tim at kartoza.com
Mon Jun 11 04:52:59 PDT 2018
Hi Denis
> On 11 Jun 2018, at 13:10, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi Tim,
> Apparently, you're using the system Python. Are you sure you have sip installed in there?
> In my config, sip is installed in /usr/local/lib/python3.6/site-packages/
Thanks for your reply. Yeah I know - I’m more trying to figure out how to get it to ignore the system install python 3. Its wierd because distils is always showing the system include dir rather than my local one e.g.:
[timlinux at sandstone ~/dev/cpp/QGIS (master)]$ /usr/local/bin/python3
Python 3.6.4 (v3.6.4:d48ecebad5, Dec 18 2017, 21:07:28)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import distutils.sysconfig
>>> distutils.sysconfig.get_python_inc()
'/Library/Frameworks/Python.framework/Versions/3.6/include/python3.6m'
I’m expecting it to return
/usr/local/Frameworks/Python.framework/Versions/3.6/include
Since I ran the brew installed python3.
Even overriding the CMAKE options in my kit always returns the /library path because FindPython calls the FindLibPython.py before doing anything else it seems.
Regards
Tim
> Denis
> Le lun. 11 juin 2018 à 05:20, Tim Sutton <tim at kartoza.com <mailto:tim at kartoza.com>> a écrit :
> Hi All (Larry?)
> Testing the latest master from today, self build on macOS, I am getting this on application start up (see below). Is this a Mac only problem? Does anyone else building on Mac Get this?
> Regards
> Tim
> Couldn't load SIP module.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
> ModuleNotFoundError: No module named 'sip'
> Python version:
> QGIS version:
> 3.1.0-Master 'Master', 4e084b63c4
> Python path:
> ['/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python', '/Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python', '/Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins', '/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins', '/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/bin/$PYTHONPATH', '/usr/local/opt/gdal2-python/lib/python3.6/site-packages', '/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip', '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6', '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload', '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages’]
> Tim Sutton
> Co-founder: Kartoza
> Ex Project chair: QGIS.org <http://qgis.org/>
> Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> Skype: timlinux
> IRC: timlinux on #qgis at freenode.net <http://freenode.net/>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer><KartozaNewLogoThumbnail.jpg><KartozaNewLogoThumbnail.jpg>
Tim Sutton
Co-founder: Kartoza
GIS Training
Consulting Services
Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/7280dd63/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/7280dd63/attachment-0001.jpg>
Desc: Message signed with OpenPGP
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180611/7280dd63/attachment-0001.sig>
More information about the QGIS-Developer mailing list
