[QGIS-Developer] issue compiling current master
Matthias Kuhn matthias at opengis.ch
Thu Jun 28 12:05:29 PDT 2018
Hi Richard,
Can you try changing the `!= 't'` to `!= QLatin1String( "t" )` and open
a PR if that solves the issue? I assume a compiler or old Qt version
compatibility issue.
And concerning the "is it appropriate to post here", I can't answer this
question, but in cases like here, where a particular line number in a
file is mentioned, it's often very efficient to comment on this line on
github, since the person in charge of the change will be notified right
away.
Cheers
Matthias
On 06/28/2018 01:44 PM, Richard Duivenvoorde wrote:
> Hi Matthias,
> Thanks, meanwhile it is fixed I think?
> Now I have this one:
> /home/richard/git/qgis/src/providers/postgres/qgspostgresprovider.cpp:
> In member function ‘virtual bool QgsPostgresProvider::empty() const’:
> /home/richard/git/qgis/src/providers/postgres/qgspostgresprovider.cpp:3203:33:
> error: no match for ‘operator!=’ (operand types are ‘QString’ and ‘char’)
>    return res.PQgetvalue( 0, 0 ) != 't';
> In file included from
> /usr/include/x86_64-linux-gnu/qt5/QtCore/qcoreapplication.h:44:0,
>                  from
> /usr/include/x86_64-linux-gnu/qt5/QtWidgets/qapplication.h:43,
>                  from
> /usr/include/x86_64-linux-gnu/qt5/QtWidgets/QApplication:1,
>                  from ../src/core/qgsapplication.h:19,
>                  from
> /home/richard/git/qgis/src/providers/postgres/qgspostgresprovider.cpp:18:
> /usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:1175:13: note:
> candidate: bool QString::operator!=(const char*) const <near match>
>  inline bool QString::operator!=(const char *s) const
> conversion of argument 1 would be ill-formed:
> /home/richard/git/qgis/src/providers/postgres/qgspostgresprovider.cpp:3203:36:
> error: invalid conversion from ‘char’ to ‘const char*’ [-fpermissive]
> I'm not sure if it is in anyway helpfull to let this know here, as I do
> not dare to fix this myself...
> But maybe others are trying to compile and fail also.
> If devs prefer that I make an issue of these, just let me know.
> Regards,
> On 06/27/2018 04:02 PM, Matthias Kuhn wrote:
>> Looks like there is a problem with the "final" keyword, probably in
>> combination with some older versions of sip.
>> I'm traveling so I don't have the possibility to fix this timely, I'm sorry.
>> https://github.com/qgis/QGIS/blob/master/python/core/auto_generated/qgsvectordataprovider.sip.in#L134
>> Matthias
>> On 06/27/2018 03:45 PM, Luigi Pirelli wrote:
>>> back to 4f25d23fc2e7f1ccf6a2798da78c0fd199fda424 allow successfully build
>>> Luigi Pirelli
>>> * LinkedIn: https://www.linkedin.com/in/luigipirelli
>>> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
>>> * GitHub: https://github.com/luipir
>>> * Mastering QGIS 2nd Edition:
>>> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>>> * Hire me: http://goo.gl/BYRQKg
>>> On Wed, 27 Jun 2018 at 14:24, Richard Duivenvoorde
>>> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>>>     Hi Devs,
>>>     I'm having an issue compiling current master:
>>>     [ 47%] Building CXX object
>>>     src/server/CMakeFiles/qgis_server.dir/moc_qgsserverlogger.cpp.o
>>>     src/server/CMakeFiles/qgis_server.dir/moc_qgsserversettings.cpp.o
>>>     [ 47%] Linking CXX shared library ../../output/lib/libqgis_server.so
>>>     sip:
>>>     /home/richard/git/qgis/build/python/core/auto_generated/qgsvectordataprovider.sip:134:
>>>     syntax error
>>>     python/CMakeFiles/python_module_qgis__core.dir/build.make:511: recipe
>>>     for target 'python/core/sip_corepart0.cpp' failed
>>>     make[2]: *** [python/core/sip_corepart0.cpp] Error 1
>>>     make[2]: *** Deleting file 'python/core/sip_corepart0.cpp'
>>>     CMakeFiles/Makefile2:3343: recipe for target
>>>     'python/CMakeFiles/python_module_qgis__core.dir/all' failed
>>>     make[1]: *** [python/CMakeFiles/python_module_qgis__core.dir/all]
>>>     Error 2
>>>     make[1]: *** Waiting for unfinished jobs....
>>>     src/gui/CMakeFiles/qgis_gui.dir/raster/qgsmultibandcolorrendererwidget.cpp.o
>>>     src/gui/CMakeFiles/qgis_gui.dir/raster/qgspalettedrendererwidget.cpp.o
>>>     src/gui/CMakeFiles/qgis_gui.dir/raster/qgsrasterbandcombobox.cpp.o
>>>     src/gui/CMakeFiles/qgis_gui.dir/raster/qgsrasterhistogramwidget.cpp.o
>>>     [ 47%] Built target qgis_server
>>>     Tried a fresh checkout, and both Ninja and make.
>>>     Anybody else seeing this?
>>>     Regards,
>>>     _______________________________________________
>>>     QGIS-Developer mailing list
>>>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Matthias Kuhn
>> matthias at opengis.ch <mailto:matthias at opengis.ch>
>> +41 (0)76 435 67 63 <tel:+41764356763>
>> OPENGIS.ch Logo <http://www.opengis.ch>
Matthias Kuhn
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180628/c627fb67/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180628/c627fb67/attachment.png>
More information about the QGIS-Developer mailing list
