[QGIS-Developer] $geometry does not consider changes in the edit uffer
Denis Rouzaud denis.rouzaud at gmail.com
Thu Mar 1 09:14:32 PST 2018
Hi all,
If I set a virtual field with the vertex count (i.e. num_points(  $geometry
) ), it does not consider changes in the edit buffer.
In other words, I have to commit the changes so the expression is correct.
Is this an expected behavior?
I would have expect to be updated directly.
Cheers,
Denis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180301/79e9f8d4/attachment.html>
More information about the QGIS-Developer mailing list
