[QGIS-Developer] $geometry does not consider changes in the edit uffer
Denis Rouzaud denis.rouzaud at gmail.com
Tue Mar 13 10:19:26 PDT 2018
Hi again,
I'd like to bump this issue once more to the list....
Anyone knows about?
Cheers,
Denis
Le jeu. 1 mars 2018 à 13:14, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Hi all,
> If I set a virtual field with the vertex count (i.e. num_points(
>  $geometry ) ), it does not consider changes in the edit buffer.
> In other words, I have to commit the changes so the expression is correct.
> Is this an expected behavior?
> I would have expect to be updated directly.
> Cheers,
> Denis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180313/82625b6f/attachment-0001.html>
More information about the QGIS-Developer mailing list
