[QGIS-Developer] $geometry does not consider changes in the edit uffer
Nyall Dawson
nyall.dawson at gmail.com
Tue Mar 13 13:47:57 PDT 2018
On 14 March 2018 at 03:19, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi again,
> I'd like to bump this issue once more to the list....
>> If I set a virtual field with the vertex count (i.e. num_points(
>> $geometry ) ), it does not consider changes in the edit buffer.
>> In other words, I have to commit the changes so the expression is correct.
>> Is this an expected behavior?
>> I would have expect to be updated directly.
I can't reproduce -- it works fine here (testing through the attribute table).
Nyall
