[QGIS-Developer] issues in QGIS Server 2,18
René-Luc Dhont
rldhont at gmail.com
Fri Mar 2 01:45:10 PST 2018
Hi devs,
An other Huge issue in QGIS Server 2.18.17:
https://issues.qgis.org/issues/18247
Regards,
René-Luc
Le 01/03/2018 à 14:26, René-Luc Dhont a écrit :
> Hi Giovanni,
> Le 01/03/2018 à 12:52, Giovanni Manghi a écrit :
>> Hi all,
>> now that 2.18 is LTR I guess that many have also updated their QGIS
>> Server installation to this release. Problem is that I see a few
>> issues in 2.18 and would like to have gsome feedback from others.
>> *) slower: it seems this version is slower compared to 2.14, at least
>> for some specific request like WFS GetFeatures. See for example:
>> https://issues.qgis.org/issues/18249#note-1
>> where in the same condition (same server, same postgis datasource of
>> around ~25000 polygons) 2.18 is about 30 seconds slower than 2.14.
> This issue is simply due to the transformation of the geometry from
> the layer CRS to the GeoJSON CRS standard: EPSG:4326
>> *) At some point in 2.18 development -in the print composer,
>> properties of a legend- the "none" value for the "map" option was
>> removed. This option (together with "auto update" unchecked) allowed
>> to do GetPrint requests where a legend always shown the same fixed
>> entries regardless of the layers being requested. Moreover now the
>> layers legend (from a GetPrint) frequently shows "?" instead of the
>> correct legend. Not sure if the two things are related.
> It will be great to have the possibility to allow nullptr in the map
> combobox.
> Nyall, do you have an idea how to enhance QgsComposerItemComboBox
> introdiuced by
> https://github.com/qgis/QGIS/commit/1b4bd47076103e931e642c9c2b6a363f14b20a45?
> Issue already exists: https://issues.qgis.org/issues/16899
>> *) Crashes on GetPrint: adding some type of elements in print
>> composers (like html text boxes) caused QGIS Server to crash when
>> doing a GetPrint *if* the *headless* server didn't had a fake xserver
>> installed. Now in 2.18 this happens even if QGIS Server is installed
>> on a Desktop OS, unless installing the fake x server. Not sure is
>> related but this now affects also Windows machines where a GetPrint
>> requests (of a layout with one of this problematic elements) make
>> always QGIS Server crash. This was not the case for 2.14.
> The solution is probably to update the environment variable
> QT_GRAPHICSSYSTEM to 'raster' has explain
> https://issues.qgis.org/issues/15440 and in a lot of other project:
> https://stackoverflow.com/questions/6168570/qgraphicsview-slow-scale-performance-under-linux
> https://forum.kde.org/viewtopic.php?t=90821
> I'll test this solution.
> Regards,
> René-Luc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180302/49c295ad/attachment.html>
