[QGIS-Developer] Issues building from source on Mac - No module named PyQt5
Timur Girgin
girgin.timur at gmail.com
Fri Mar 9 09:06:59 PST 2018
Well, you might just be right since I could not get some of the packages
working off of brew (due to installation issues, or unavailability). Some
of them were build from source (e.g., SIP), which might be causing the
issue that you are talking about.
And no, I have not been using Remi's formula.
What I am trying to accomplish is to create a QGIS installer for Mac since
there seems to be demand for one, though I have little experience in doing
so.
Thank you for your help
On Fri, Mar 9, 2018 at 11:40 AM, Carlo A. Bertelli (Charta s.r.l.) <
carlo.bertelli at gmail.com> wrote:
> This discussion is going a bit off-topic, but I think the problem could be
> in your Homebrew installation. If someone changes the reference to qt from
> qt4 to qt5 may cause some issue (I call it a mess, but I am biased, I had a
> very bad time with these issue – thanks to Larry did fix them). Maybe you
> will have to uninstall all qt related formulas and reinstall qt 4 and 5.
> I see Remi Desgrange made a formula for the released QGIS 3 here:
> https://github.com/RemiDesgrange/homebrew-qgisrelease
> Are you using it?
> c
> On Fri, Mar 9, 2018 at 5:22 PM, Timur Girgin <girgin.timur at gmail.com>
> wrote:
>> Hello Carlo,
>> Would you advice building Qt5 from source then, rather than using brew?
>> Thanks
>> On Fri, Mar 9, 2018 at 11:13 AM, Carlo A. Bertelli (Charta s.r.l.) <
>>> Hello,
>>> I suggest to remind that using Homebrew carries in another issue. The
>>> maintainers decided to force everyone to use Qt5 as Qt4 is deprecated by Qt
>>> developers. Everything that was called qt5-something should become
>>> qt-something, so everyone who uses Qt4 had to make formulas called
>>> qt4-something for every Qt4 dependency.
>>> This was the case even for OsGeo4Mac (https://github.com/OsGeo/home
>>> brew-osgeo4mac/) and Larry Shaffer had to recreate all the needed
>>> dependencies inside this tap. If you have old Qt dependencies inside your
>>> Homebrew, it may happen that qt-something is still qt4-something even if
>>> brew thinks it's qt5... Feeling bewildered? So am I.
>>> c
>>> On Thu, Mar 8, 2018 at 4:10 PM, Timur Girgin <girgin.timur at gmail.com>
>>> wrote:
>>>> Hello everyone,
>>>> I am having trouble building the QGIS release-3_0 branch on my Mac. I
>>>> finally got it to cmake, however I am getting an error during the make
>>>> process in which it seems that spatialite is using the system's Python(@2)
>>>> executable to find PyQT5 when in reality it should be looking for it in the
>>>> Python at 3 executable that has been given during CMAKE. I am guessing
>>>> this is what is causing the issue.
>>>> Please find the error at the bottom of this email. If anyone knows what
>>>> I am doing wrong, would you please let me know?
>>>> Thank you very much!
>>>> Tim
>>>> Here is my CMAKE:
>>>> cmake -D CMAKE_INSTALL_PREFIX=~/Downloads/QGIS-build \
>>>> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>>>> -D SPATIALINDEX_LIBRARY=/usr/local/Cellar/spatialindex/1.8.5/lib/libspatialindex.4.dylib
>>>> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/Cellar/spatialindex/1.8.
>>>> 5/include/spatialindex/\
>>>> -D QWT_LIBRARY=/usr/local/qwt-6.1.3/lib/libqwt.dylib \
>>>> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.1.3/include \
>>>> -D BISON_EXECUTABLE=/usr/local/Cellar/bison/3.0.4_1/bin/bison \
>>>> -D GEOS_LIBRARY=/usr/local/Cellar/geos/3.6.2/lib/libgeos.dylib \
>>>> -D GEOS_INCLUDE_DIR=/usr/local/Cellar/geos/3.6.2/include \
>>>> -D LIBZIP_LIBRARY=/usr/local/Cellar/libzip/1.4.0/lib/libzip.5.0.dylib
>>>> -D LIBZIP_INCLUDE_DIR=/usr/local/Cellar/libzip/1.4.0/include \
>>>> -D LIBZIP_CONF_INCLUDE_DIR=/usr/local/Cellar/libzip/1.4.0/include \
>>>> -D EXPAT_LIBRARY=/usr/local/Cellar/expat/2.2.5/lib/libexpat.1.6.7.dylib
>>>> -D EXPAT_INCLUDE_DIR=/usr/local/Cellar/expat/2.2.5/include \
>>>> -D Qt5Core_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Core \
>>>> -D Qt5Gui_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Gui \
>>>> -D Qt5Test_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Test \
>>>> -D Qt5Widgets_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Widgets \
>>>> -D Qt5Concurrent_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Concurrent
>>>> -D Qt5OpenGL_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5OpenGL \
>>>> -D Qt5Xml_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Xml \
>>>> -D Qt5Svg_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Svg \
>>>> -D Qt5Network_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Network \
>>>> -D Qt5PrintSupport_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5PrintSupport
>>>> -D Qt5Positioning_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Positioning
>>>> -D Qt5XmlPatterns_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5XmlPatterns
>>>> -D Qt5WebKit_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5WebView \
>>>> -D Qt5UiTools_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5UiTools \
>>>> -D Qt5Sql_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Sql \
>>>> -D QCA_INCLUDE_DIR=/usr/local/Cellar/qt/5.10.1/lib/qca-qt5.framework/Versions/2.1.3/Headers
>>>> -D QCA_LIBRARY=/usr/local/Cellar/qt/5.10.1/lib/qca-qt5.framework/Versions/2.1.3/qca-qt5
>>>> -D LIBTASN1_LIBRARY=/usr/local/Cellar/libtasn1/4.13/lib/libtasn1.6.dylib
>>>> -D LIBTASN1_INCLUDE_DIR=/usr/local/Cellar/libtasn1/4.13/include \
>>>> -D QSCINTILLA_INCLUDE_DIR=/usr/local/Cellar/qscintilla2/2.10.2_1/include
>>>> -D QSCINTILLA_LIBRARY=/usr/local/Cellar/qscintilla2/2.10.2_1/li
>>>> b/libqscintilla2_qt5.13.1.0.dylib \
>>>> -D QTKEYCHAIN_INCLUDE_DIR=/usr/local/Cellar/qtkeychain/0.8.0/include
>>>> -D QTKEYCHAIN_LIBRARY=/usr/local/Cellar/qtkeychain/0.8.0/lib/libqt5keychain.0.8.0.dylib
>>>> -D SPATIALITE_LIBRARY=/usr/local/Cellar/libspatialite/4.3.0a_6/lib/mod_spatialite.7.dylib
>>>> -D SPATIALITE_INCLUDE_DIR=/usr/local/Cellar/libspatialite/4.3.0a_6/include
>>>> -D SQLITE3_LIBRARY=/usr/local/Cellar/sqlite/3.22.0/lib/libsqlite3.0.dylib
>>>> -D PYTHON_EXECUTABLE=/usr/local/bin/python3 \
>>>> -D PYTHON_INCLUDE_PATH=/usr/local/Frameworks/Python.framework/Versions/3.6/Headers
>>>> -D PYTHON_LIBRARY=/usr/local/Frameworks/Python.framework/Versions/3.6/Python
>>>> -D WITH_QTWEBKIT=FALSE \
>>>> Which outputs:
>>>> -- QGIS version: 3.0.0 Girona (30000)
>>>> -- Could not find GRASS 7
>>>> -- Found Proj: /Library/Frameworks/PROJ.framework
>>>> -- Found GEOS: /usr/local/Cellar/geos/3.6.2/lib/libgeos.dylib (3.6.2)
>>>> -- Found GDAL: /usr/local/Cellar/gdal2/2.2.3/lib/libgdal.dylib (2.2.3)
>>>> -- Found Expat: /usr/local/Cellar/expat/2.2.5/lib/libexpat.1.6.7.dylib
>>>> -- Found Spatialindex: /usr/local/Cellar/spatialindex
>>>> -- Found Qwt: /usr/local/qwt-6.1.3/lib/libqwt.dylib (6.1.3)
>>>> -- Found libzip: /usr/local/Cellar/libzip/1.4.0/lib/libzip.5.0.dylib
>>>> -- Found Sqlite3: /usr/local/Cellar/sqlite/3.22.
>>>> -- Found PostgreSQL: /usr/local/lib/libpq.dylib
>>>> -- Found SpatiaLite: /usr/local/Cellar/libspatialit
>>>> -- Qt WebKit support DISABLED.
>>>> -- Found Qt version: 5.10.1
>>>> -- Found QScintilla2: /usr/local/Cellar/qscintilla2/
>>>> 2.10.2_1/lib/libqscintilla2_qt5.13.1.0.dylib (2.10.2)
>>>> -- Found QtKeychain: /usr/local/Cellar/qtkeychain/0
>>>> -- Found QCA: /usr/local/Cellar/qt/5.10.1/li
>>>> b/qca-qt5.framework/Versions/2.1.3/qca-qt5 (2.1.3)
>>>> -- QtCore/QCA include/lib variables missing or CMake is cross-compiling,
>>>> -- skipping QCA OpenSSL plugin C++ check
>>>> -- Pedantic compiler settings enabled
>>>> -- Found Python executable: /usr/local/bin/python3
>>>> -- Found Python version: 3.6.4
>>>> -- Found Python library: /usr/local/Frameworks/Python.f
>>>> -- Found Python site-packages: /usr/local/lib/python3.6/site-packages
>>>> pyqt_version:050a01
>>>> pyqt_version_num:330241
>>>> pyqt_version_str:5.10.1
>>>> pyqt_version_tag:
>>>> pyqt_mod_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/Pyt
>>>> hon.framework/Versions/3.6/lib/python3.6/site-packages/PyQt5
>>>> pyqt_sip_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/Pyt
>>>> hon.framework/Versions/3.6/share/sip
>>>> pyqt_sip_flags:-t WS_MACX -t Qt_5_10_1
>>>> pyqt_bin_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/Pyt
>>>> hon.framework/Versions/3.6/bin
>>>> -- Found PyQt5 version: 5.10.1
>>>> -- Found SIP version: 4.19.8
>>>> -- Found QScintilla2 PyQt module: 2.10.2
>>>> -- txt2tags not found - disabled
>>>> -- Found GSL: -L/usr/local/Cellar/gsl/2.4/lib -lgsl -lgslcblas
>>>> -- Qsci sip file not found - disabling bindings for derived classes
>>>> -- Configuring done
>>>> -- Generating done
>>>> -- Build files have been written to: /Users/tgirgin/Downloads/QGIS/
>>>> build
>>>> I added a MESSAGE to output the version and more of PyQt5, and it seems
>>>> to be exactly where I expect it to be. However, during make it is being
>>>> looked for using Python2.
>>>> Output of make -j8:
>>>> [ 9%] Built target zzz-MetaSearch-47-depend
>>>> [ 9%] Built target zzz-MetaSearch-46-depend
>>>> [ 9%] Built target zzz-MetaSearch-45-depend
>>>> [ 9%] Generating resources_rc.py
>>>> [ 9%] Built target zzz-db_manager-13-depend
>>>> [ 9%] Built target pyutils
>>>> [ 9%] Built target zzz-db_manager-12-depend
>>>> /System/Library/Frameworks/Python.framework/Versions/2.7/Res
>>>> ources/Python.app/Contents/MacOS/Python: No module named PyQt5
>>>> make[2]: *** [python/plugins/db_manager/resources_rc.py] Error 1
>>>> make[1]: *** [python/plugins/db_manager/CMa
>>>> keFiles/zzz-db_manager-14-depend.dir/all] Error 2
>>>> make[1]: *** Waiting for unfinished jobs....
>>>> [ 9%] Built target zzz-db_manager-2-depend
>>>> [ 9%] Built target zzz-db_manager-6-depend
>>>> [ 9%] Built target zzz-db_manager-4-depend
>>>> make[2]: *** [python/plugins/db_manager/db_
>>>> plugins/postgis/resources_rc.py] Error 1
>>>> make[1]: *** [python/plugins/db_manager/db_
>>>> plugins/postgis/CMakeFiles/zzz-db_manager-1-depend.dir/all] Error 2
>>>> make: *** [all] Error 2
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Carlo A. Bertelli
>>> Charta servizi e sistemi per il territorio e la storia ambientale srl
>>> Dipendenze del palazzo Doria,
>>> vc. alla Chiesa della Maddalena 9/2 16124 Genova (Italy)
>>> tel./fax +39(0)10 2475439 +39 0108566195
>>> <+39%20010%20856%206195> mobile:+39 393 1590711
>>> <+39%20393%20159%200711>
>>> e-mail: bertelli at chartasrl.eu http://www.chartasrl.eu
> Carlo A. Bertelli
> <+39%20010%20856%206195> mobile:+39 393 1590711 <+39%20393%20159%200711>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180309/b7d35eaa/attachment-0001.html>
