[QGIS-Developer] 来自Kurt Stine的邮件
Kurt Stine
qiangong2 at 126.com
Sat Mar 10 23:37:02 PST 2018
They are the same size.
I wonder if the issue is mainly due to the cmake error that is being thrown. I put the link in a previous mail, but here it is: https://hastebin.com/woherijadi.tex
It says that there are unresolved externals.
Here is the cmakeoutput.txt file: https://hastebin.com/zopepezabo.tex
Kurt
>> C:\OSGeo4W/lib\spatialite.lib
>> C;\OSGeo4W\lib\spatialite_i.lib
This naming convention seems to be normal for OSGeo4W.
I found a site that contains the 32 bit Spatialite 4.3 version:
http://www.norbit.de/~jef/osgeo4w/x86/release/spatialite/
http://www.norbit.de/~jef/osgeo4w/x86/release/spatialite/spatialite-4.3.0-4.tar.bz2
05-Nov-2017 20:455.6M
149310 Nov 5 20:44 spatialite_i.lib
13892352 Nov 5 20:44 spatialite.lib
# 'nm' is a linux command to list the symbols in an object file
# -> first with an original linux spatialite 4.3:
nm libspatialite.so.7.1.0 | grep gaiaStatisticsInvalidate
000000000016bd89 T gaiaStatisticsInvalidate
- which finds 'gaiaStatisticsInvalidate'
# The same on the windows 'spatialite_i.lib' from www.norbit.de
nm spatialite_i.lib | grep gaiaStatisticsInvalidate
00000000 T _gaiaStatisticsInvalidate
00000000 I __imp__gaiaStatisticsInvalidate
- also bring a result, nice to know it also works with windows binaries
So I would compare the date and size of the 2 files with yours and if not the same download the archive from www.norbit.de and try that.
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180311/a3cc020b/attachment-0001.html>
