[QGIS-Developer] issues in QGIS Server 2,18
René-Luc Dhont
rldhont at gmail.com
Fri Mar 16 06:51:28 PDT 2018
Hi Giovanni,
I have found the reason why QGIS Server 2.18 and probably 3 are slower
than 2.14 in generating GeoJSON.
I'll fix it.
Regards,
René-Luc
Le 09/03/2018 à 17:43, Régis Haubourg a écrit :
> Hi Giovanni,
> GetFeatures can output GML with a different format.
> What is sure is that GeoJSON spec doesn't leave any choice, unless we
> go for a proprietary output format allowing another SRS.
> I'll keep that in mind when testing OGC compliancy for WFS. We are
> working on that currently to evaluate how much work is needed to reach
> a certification for WFS.
> Regards
> Régis
> 2018-03-09 14:34 GMT+01:00 Giovanni Manghi <giovanni.manghi at gmail.com
> <mailto:giovanni.manghi at gmail.com>>:
> Hi René-Luc,
> > Le 01/03/2018 à 12:52, Giovanni Manghi a écrit :
> >> Hi all,
> >> now that 2.18 is LTR I guess that many have also updated their QGIS
> >> Server installation to this release. Problem is that I see a few
> >> issues in 2.18 and would like to have gsome feedback from others.
> >> *) slower: it seems this version is slower compared to 2.14, at
> least
> >> for some specific request like WFS GetFeatures. See for example:
> >> https://issues.qgis.org/issues/18249#note-1
> <https://issues.qgis.org/issues/18249#note-1>
> >> where in the same condition (same server, same postgis
> datasource of
> >> around ~25000 polygons) 2.18 is about 30 seconds slower than 2.14.
> > This issue is simply due to the transformation of the geometry
> from the
> > layer CRS to the GeoJSON CRS standard: EPSG:4326
> ok thanks, but one doubt: I guess that this change (compared to 2.14)
> was to make qgis server more compliant and this also means that we
> need to accept that for such requests will be always slower than it
> was before? sorry for the dumb question as I'm not much into the ogc
> internals.
> cheers
> -- G --
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe:
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180316/94a80cab/attachment.html>
