[QGIS-Developer] Problem with symbology rule containing @atlas_featureid
Andreas Neumann a.neumann at carto.net
Fri Mar 23 05:47:27 PDT 2018
I noticed a big problem in the rule based renderer when PostgreSQL
layers are involved and the rule contains @atlas_featureid.
As an example, I use this rule:
$id != @atlas_featureid
When I click on the "Test" button I get "Filter returned xxxx features".
So far so good. But the bad thing: nothing is drawn on the canvas!
Could it be that the expression compiler tries to forward this query,
but PostgreSQL knows nothing about @atlas_featurid ?
Can someone confirm that this really is the case before I file an issues
report?
Thanks a lot,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180323/cca8bc75/attachment.html>
More information about the QGIS-Developer mailing list
