[QGIS-Developer] Error when saving Processing Script QGIS master
matteo
matteo.ghetta at gmail.com
Sat Mar 24 03:14:52 PDT 2018
Hi Nyall,
> Does it help if you inherit from QgsProcessingAlgorithm instead?
> There's no need to inherit from QgisAlgorithm here, you should use the
> base class directly.
nope.. I already changed that so that now the class inherits from
QgsProcessingAlgorithm.
I also noticed that I have to put:
def createInstance(self):
return type(self)()
else the algorithm will crash..
Thanks
Matteo
