[QGIS-Developer] Error when saving Processing Script QGIS master
Nyall Dawson
nyall.dawson at gmail.com
Fri Mar 23 17:15:49 PDT 2018
On 23 March 2018 at 17:39, matteo <matteo.ghetta at gmail.com> wrote:
> Hi all,
> I really don't know if I'm missing something basic, but even with this
> super short script (that does not run anything):
> from processing.algs.qgis.QgisAlgorithm import QgisAlgorithm
> class myScript(QgisAlgorithm):
Does it help if you inherit from QgsProcessingAlgorithm instead?
There's no need to inherit from QgisAlgorithm here, you should use the
base class directly.
Nyall
> INPUT = 'INPUT'
> OUTPUT = 'OUTPUT'
> def group(self):
> return 'My group'
> def name(self):
> return 'my algorithm'
> from the editor I can run it (and the dialog pops up normally, even
> without parameters), I can save it, but when I close it than the same
> error appears:
> NotImplementedError: QgsProcessingAlgorithm.name() is abstract and must
> be overridden
> Cheers and thanks for any hint
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
