[QGIS-Developer] issues in QGIS Server 2,18
René-Luc Dhont
rldhont at gmail.com
Thu Mar 29 04:32:49 PDT 2018
Hi giovanni,
I'd like to try the WFS QGIS Server service ?
Regards,
René-Luc
Le 28/03/2018 à 12:38, Giovanni Manghi a écrit :
> Hi all,
>>> I have found the reason why QGIS Server 2.18 and probably 3 are slower
>>> than 2.14 in generating GeoJSON.
>>> I'll fix it.
> I discovered two more WFS related issues, one in QGIS Desktop the
> other in the Server.
> I setup a WFS service, with both QGIS Server 2.18 and Mapserver, with
> a layer than contains 5.6million points.
> The QGIS WFS client pulls this layer without issues, but there is a
> big problem when identifying features with the option "auto open form"
> enabled:
> on the second identify operation QGIS freezes and it start to leak
> memory until it eats it all. It does not happen if the "auto open
> form" option is not enabled. This happens also on QGIS 3.
> The second issue is about the same dataset published as WFS with QGIS
> Server, when saving the layer using QGIS using "save as" (for example
> to a geopackage) the result is missing several features/points.
> I tried then to save the layer using ogr from th CLI, and at some
> point the message "ERROR 1: XML parsing of GML file failed : unclosed
> token at line 109413441, column 21" is shown. This is not happening
> (and the result is complete) if server used is Mapserver.
> I can provide the services URLs is someone wants to give it a try.
> cheers!
> -- G --
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
