[QGIS-Developer] What are "Key/value" and "List" widgets in attributes form?
DelazJ
delazj at gmail.com
Thu Mar 29 08:58:10 PDT 2018
Thanks Nyall. Indeed, these are PG provider tools. I dug a bit and found
out that list is designed for array field type while key/value refers to
hstore field type.
Doc is updated (might be light but better than nothing imho).
Harrissou
2018-03-24 1:18 GMT+01:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 23 March 2018 at 00:07, DelazJ <delazj at gmail.com> wrote:
> > Hi all,
> > In the vector layer properties dialog, Attributes form tab, I fail to
> > understand/find what enables those two widgets, hence what they are
> supposed
> > to do and how they could work.
> > If someone has some information, thanks for sharing.
> > Documenting this section is blocked by these information (see
> > https://github.com/qgis/QGIS-Documentation/pull/2437/files)
> I suspect these are only available for list/map field types - which as
> far as I'm aware are only available for the postgres provider.
> Nyall
> > Thanks,
> > Harrissou
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180329/201dc466/attachment.html>
