[QGIS-Developer] R provider for QGIS 3 - any interest?
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Wed May 2 05:27:00 PDT 2018
I'm sure sf is the future for spatial objects. There are not too many
examples and resources to be found on the web still, but I ported one of
my (poor scripts) from sp to sf. It's now maybe 25% of code and maybe 10
times faster.
Though there are numerous packages with dependencies for sp, which will
not change for a long time.
I have to admit, I never managed to get R code work properly in QGIS
(documentation?) but stuck to R studio and just did the post-processing
within QGIS. Having the ability to work properly within QGIS would maybe
boost the efficiency to a new level.
Am 02.05.2018, 07:57 Uhr, schrieb Howard Frederick <simbamangu at gmail.com>:
> Having an R console within QGIS would be incredibly useful! I've been
> copying and pasting between R and QGIS (keeping the WKT field >correctly
> formatted) using read.table, which works well, too. W.r.t. sp vs. sf,
> seems like sf is the future for R spatial objects? >Any thoughts on this?
> Crowdfunding definitely seems like the way forward - which platforms
> have been used for this kind of project in the past?
> On Fri, 27 Apr 2018 at 03:10, Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> On 26 April 2018 at 22:10, Barry Rowlingson
>> <b.rowlingson at lancaster.ac.uk> wrote:
>>> As a long-time R spatial developer and QGIS user I'll be glad to help
>>> out -
>>> but time-poor at work for now. "Helping out" may be more like "making
>>> unreasonable suggestions" and "finding annoying bugs".
>> Don't undersell yourself... these would be very valuable contributions!
>>> For example, can we find a more efficient way to transfer data from
>>> QGIS to
>>> R? Can the new `sf` packages in R work with the data straight out of
>>> QGIS'
>>> memory? I *think* the `sf` package stores vector data in GDALs native
>>> C++
>>> objects, and if QGIS is doing that too then we *might* be able to get
>>> access
>>> from QGIS and R if we write the R plugin as a C/C++ module that
>>> dynamically
>>> links with the shareable libR.so.
>> I've (very roughly) looked into this, and I also believe it should be
>> possible to directly create R data frames from QGIS layers. Then we'd
>> just need to add a "R console" to QGIS, and boom! Awesome spatial
>> statistical analysis tool directly within QGIS!
>> Nyall
>>> The current R processing plugin converts QGIS layers to shapefiles,
>>> reads
>>> them into a new R process. On occasion I've hit problems with shapefile
>>> limitations (field name length, usually) that make my scripts fail.
>>> Maybe it
>>> should go via geopackage instead.
>>> Should it create `sp` objects on the R side or `sf` objects? This
>>> could be
>>> controllable in the R processing script headers, so it can be set on a
>>> per-script basis.
>>> I'll stop now...
>>> Barry
>>> On Thu, Apr 26, 2018 at 9:42 AM, Aurelio Pires <anvpires at gmail.com>
>>> wrote:
>>>> +1
>>>> Thanks,
>>>> On 2018-04-26 07:40, Paolo Cavallini wrote:
>>>> > Hi all,
>>>> > Il 26/04/2018 05:08, Nyall Dawson ha scritto:
>>>> >> I'm VERY interested in seeing this resurrected. I'm available to
>>>> >> mentor this task if someone else wants to take ownership of the
>>>> plugin
>>>> >> and do the port, OR alternatively I'd be happy for North Road to do
>>>> >> the porting ourselves and take over maintenance if someone can fund
>>>> >> this work.
>>>> > that's good news. So starting a crowdfunding campaign seems a good
>>>> way
>>>> > to go, unless there is a bigger sponsor; do you agree?
>>>> > All the best, and thanks.
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180502/4265476c/attachment-0001.html>
