[QGIS-Developer] Compiling QGIS 3 on Centos 7
Andreas Neumann
a.neumann at carto.net
Thu May 3 02:46:22 PDT 2018
Hi again,
Seems like CentOS 7.5 (release due soon) comes with qt 5.9.2 - just have
to be patient a bit and hope that all other dependencies will also be
more up-to-date.
As an example, CentOS 7.4 only comes with GDAL 1.11 - they are very
conservative!
Andreas
On 2018-05-03 11:32, Andreas Neumann wrote:
> Hi Richard,
> Yeah - CentOS7 is currently stuck with qt 5.6
> I probably have to give up on getting QGIS server 3 to run on CentOS7 :-(
> The only way would be a dockerized version of QGIS server 3 - or I can convince our IT-department to switch to a more modern distro.
> Thanks anyway,
> Andreas
> On 2018-05-03 10:56, Richard Duivenvoorde wrote:
> On 02-05-18 17:40, Andreas Neumann wrote: Hi,
> Did someone successfully compile QGIS 3 on Centos 7?
> Or are there any recent QGIS 3 server packages available for Centos 7? I
> don't need 3d or desktop on this machine - only server.
> While I can find qt5 packages for centos 7, several other dependencies
> are not available, such as the qt5-scintilla packages or qwt for qt5, etc.
> I would be grateful for any hints or recipes how to install qgis3-server
> on centos 7 or compile it myself (meaning getting the necessary
> dependencies).
> Or would be a dockerized QGIS 3 server version be easier to install QGIS
> server 3 on Centos7?
> Hi Andreas,
> some googling:
> https://centos.pkgs.org/7/epel-x86_64/qt5-qtwebkit-5.6.2-1.el7.x86_64.rpm.html
> Seems to me 5.6 is the latest easily installable epel package?
> Not sure what minimal Qt version is for qgis...
> Though: https://github.com/qgis/QGIS/blob/master/CMakeLists.txt#L297
> seems to say 5.9.2 (no 3D off course)
> The dockerized version is the also a way to go..
> ps I have some OLD(!) compile instructions for QGIS 2(!) on centos7:
> http://zuidt.nl/blog/html/2015/10/12/build_qgis_master_with_oracle_provider_yourself_on_centos7.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180503/6d381939/attachment.html>
