[QGIS-Developer] Compiling QGIS 3 on Centos 7
Marco Bernasocchi
marco at opengis.ch
Fri May 4 06:32:29 PDT 2018
Hi Andreas,
without 3D CMake seems to require 5.2.
5.6 should be no issue, in fact Ubuntu 16.04 has Qt 5.6.
(https://packages.ubuntu.com/xenial/qt5-default) - there you need to use
ubuntugis due to other dependencies issues.
Cheers
Marco
On 03.05.2018 11:46, Andreas Neumann wrote:
> Hi again,
> Seems like CentOS 7.5 (release due soon) comes with qt 5.9.2 - just
> have to be patient a bit and hope that all other dependencies will
> also be more up-to-date.
> As an example, CentOS 7.4 only comes with GDAL 1.11 - they are very
> conservative!
> Andreas
> On 2018-05-03 11:32, Andreas Neumann wrote:
>> Hi Richard,
>> Yeah - CentOS7 is currently stuck with qt 5.6
>> I probably have to give up on getting QGIS server 3 to run on CentOS7 :-(
>> The only way would be a dockerized version of QGIS server 3 - or I
>> can convince our IT-department to switch to a more modern distro.
>> Thanks anyway,
>> Andreas
>> On 2018-05-03 10:56, Richard Duivenvoorde wrote:
>> On 02-05-18 17:40, Andreas Neumann wrote:
>> Hi,
>> Did someone successfully compile QGIS 3 on Centos 7?
>> Or are there any recent QGIS 3 server packages available for
>> Centos 7? I
>> don't need 3d or desktop on this machine - only server.
>> While I can find qt5 packages for centos 7, several other
>> dependencies
>> are not available, such as the qt5-scintilla packages or qwt
>> for qt5, etc.
>> I would be grateful for any hints or recipes how to install
>> qgis3-server
>> on centos 7 or compile it myself (meaning getting the necessary
>> dependencies).
>> Or would be a dockerized QGIS 3 server version be easier to
>> install QGIS
>> server 3 on Centos7?
>> Hi Andreas,
>> some googling:
>> https://centos.pkgs.org/7/epel-x86_64/qt5-qtwebkit-5.6.2-1.el7.x86_64.rpm.html
>> Seems to me 5.6 is the latest easily installable epel package?
>> Not sure what minimal Qt version is for qgis...
>> Though: https://github.com/qgis/QGIS/blob/master/CMakeLists.txt#L297
>> seems to say 5.9.2 (no 3D off course)
>> The dockerized version is the also a way to go..
>> ps I have some OLD(!) compile instructions for QGIS 2(!) on centos7:
>> http://zuidt.nl/blog/html/2015/10/12/build_qgis_master_with_oracle_provider_yourself_on_centos7.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
Marco Bernasocchi
QGIS.org Co-chair
marco at opengis.ch <mailto:marco at opengis.ch>
+41 (0)79 467 24 70 <tel:+41794672470>
OPENGIS.ch Logo <https://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180504/6748c275/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180504/6748c275/attachment-0001.png>
