[QGIS-Developer] Compiling QGIS3 on Ubuntu problems
Patrick Dunford enzedrailmaps at gmail.com
Sat May 5 17:37:18 PDT 2018
The shortcut parameters is the one to consider if you have mulitple
versions installed. If I am building it often it is so I can have
several different versions
On 06/05/18 09:17, Paulo van Breugel wrote:
> Thanks Patrick, adding the export statement to the file ~/.profile
> does the trick for me.
> On 05-05-18 12:07, Patrick Dunford wrote:
>> The shortcut used to start it has to specify LD_LIBRARY_PATH in the
>> shortcut parameters
>> On 05/05/18 07:15, Etienne Trimaille wrote:
>>> Have a look on https://github.com/qgis/QGIS/blob/master/INSTALL and
>>> search "error while loading shared libraries". Does it help?
>>> 2018-05-04 15:11 GMT-04:00 Paulo van Breugel <p.vanbreugel at gmail.com
>>> <mailto:p.vanbreugel at gmail.com>>:
>>>     Dear devs,
>>>     I am trying to compile QGIS3 (release_3-0) on a freshly install
>>>     Ubuntu
>>>     18.04 (bionic). All seems to go well, no error messages during
>>>     configuration or running make and make install.
>>>     When trying to run QGIS, however, I am getting the following error:
>>>     ./qgis: error while loading shared libraries: libqgis_app.so.3.0.2:
>>>     cannot open shared object file: No such file or directory
>>>     Any idea what went wrong here, and how to solve this?
>>>     Best wishes,
>>>     Paulo
>>>     _______________________________________________
>>>     QGIS-Developer mailing list
>>>     QGIS-Developer at lists.osgeo.org
>>>     <mailto:QGIS-Developer at lists.osgeo.org>
>>>     List info:
>>>     https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>     Unsubscribe:
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180506/d79c37fb/attachment.html>
More information about the QGIS-Developer mailing list
