[QGIS-Developer] Improve GRASS GIS integration in QGIS 3 - Week 2 Report
Nyall Dawson
nyall.dawson at gmail.com
Sun May 27 16:36:44 PDT 2018
On 27 May 2018 at 23:06, Radek Novotný <radeknovotny94 at gmail.com> wrote:
> Hi All,
> This is my report for Week 2 (May 21 - May 27):
> What did you get done this week?
> Implementation of an initial version of the library for parsing description
> files for QGIS Processing plugin. I solved the problem with creating XML
> files from week 1. [1]
> Create an independent version of Processing plugin for development. [1]
> Try to create GUI Integration from generated description UI files from
> initial Python library to Processing plugin [1]
Nice work Radek!
Obviously still very early days, but you seem to be on the right track
so far -- keep it up!
Cheers,
Nyall
> Details can be found in [1].
> What do you plan on doing next week?
> Final Python library for parsing descriptions
> Deep integration of UI descriptions to GUI Processing plugin
> Split GRASS module parameters in Processing plugin to basic and advanced
> tabs.
> Are you blocked on anything?
> No, at the moment I’m not blocked.
> The wiki page can be found in [3]
> [1] https://github.com/radeknovotny94/GRASS_Parse_to_QGIS_UI
> [2] https://github.com/radeknovotny94/GRASSIntegrationInQGIS3
> [3] https://trac.osgeo.org/grass/wiki/GSoC/2018/IntegrationInQGIS3
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
