[QGIS-Developer] OGR: sqlite with subset query, QgsOgrFeatureIterator::fetchFeature with SpatialFilterRect always returns feature with id 0
Nyall Dawson nyall.dawson at gmail.com
Sun May 27 17:43:33 PDT 2018
On 4 September 2017 at 18:56, Sandro Mani <manisandro at gmail.com> wrote:
> On 03.09.2017 23:50, Even Rouault wrote:
>> Ok, so if we only do this for non-select queries, we should be safe?
> Yes. I suspect the case where a full SELECT statement is used are rare, and
> people able to do that can tweak the request. It would be unreliable to try
> modifying it.
>> > > Something like this [1] seems to fix the issue, don't know if it's the
>> > > best way forward though?
>> > I've left a few comments in the commit
>> Many thanks. I've pushed a revised version at [1].
> I've added a couple suggestions for more robustness, but looks good to me.
> Thanks, filed PR: https://github.com/qgis/QGIS/pull/5122
I've been tracking down a performance regression in 3.0 and have
tracked it back to this PR.
What's happening is that in
https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrfeatureiterator.cpp#L204
, everytime a new feature is requested with a particular ID the ENTIRE
layer is being read until that feature is found! This destroys QGIS
performance when more than a handful of feature IDs are requested -
e.g. try setting a subset string on a layer, then selecting a couple
of hundred points and zooming to selection.
I've been trying to find a good solution to this without luck - if I
use OGR_L_SetAttributeFilter to specifically request the desired
feature with orig_ogr_fid equal to the requested feature id, then it's
a bit better. There's no longer the need to iterate through all the
features, but it's still very very slow compared to a direct
OGR_L_GetFeature call.
Even do you have any good tricks we could utilise here to speed this
up? Any other pointers for approaches to test?
Regards,
Nyall
More information about the QGIS-Developer mailing list
