[QGIS-Developer] is QGIS Server 3.4 working?
umbertofilippo
umbertofilippo at tiscali.it
Sat Nov 3 10:06:39 PDT 2018
Sorry to jump in but I have a problem with my QGIS SERVER 3 installation and
I think this might be the right place to post it.
First of all, let me tell you that i already post my problem on
gis.stackexchange
<https://gis.stackexchange.com/questions/301305/qgis-server-3-service-service-unknown-or-unsupported>
, QGIS BUG REPORT 18230 <https://issues.qgis.org/issues/18230#note-13>
(closed but related), and finally github QGIS PR 6502
<https://github.com/qgis/QGIS/pull/6502#issuecomment-434884447> (closed
but related)
The problem I am having> I installed QGIS SERVER 3.4 on a virtual machine
with Ubuntu Server 18.04 bionic.
I followed along the official training docs
<https://docs.qgis.org/testing/en/docs/training_manual/qgis_server/install.html>
(also for version 2.18
<https://docs.qgis.org/2.18/en/docs/training_manual/qgis_server/install.html>
) and at the end all seemed to be working - doing curl
http://qgis.demo/cgi-bin/qgis_mapserv.fcgi I receive:
<ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc">
<ServiceException code="Service configuration error">Service unknown or
unsupported</ServiceException>
</ServiceExceptionReport>
However, when I move on to lesson Serving WMS
<https://docs.qgis.org/2.18/en/docs/training_manual/qgis_server/wms.html> ,
download the demo data from here
<https://github.com/qgis/QGIS-Training-Data/tree/QGIS-Training-Data-v2.0/training_manual_data>
, unpack the qgis-server-tutorial-data in my /home/ubuntu/qgis/projects/
folder and do curl
http://qgis.demo/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS%26VERSION=1.3.0%26REQUEST=GetCapabilities%26map=/home/ubuntu/qgis/projects/qgis-server-tutorial-data/world3.qgs,
I still receive the same Service unknown or unsupported exception.
I also tried to create a personal project using the same version (3.4) of
QGIS DESKTOP and copy the needed files (only a SHP and the .qgs) to the same
projects folder, but with the same result.
Eventually, I paste both the apache and qgis-server logs in order to give a
possible answerer a possibility to dig in this issue. Any help would be very
much appreciated as I am really interested in trying QGIS SERVER. Otherwose,
do you suggest to move to an older version (like 2.18)?
*/var/log/apache2/error.log*
[Sat Nov 03 06:25:01.926915 2018] [mpm_event:notice] [pid 25821:tid
139991983651776] AH00489: Apache/2.4.29 (Ubuntu) mod_fcgid/2.3.9 configured
-- resuming normal operations
[Sat Nov 03 06:25:01.926933 2018] [core:notice] [pid 25821:tid
139991983651776] AH00094: Command line: '/usr/sbin/apache2'
[Sat Nov 03 15:41:23.482084 2018] [mpm_event:notice] [pid 25821:tid
139991983651776] AH00491: caught SIGTERM, shutting down
[Sat Nov 03 15:41:23.597896 2018] [mpm_event:notice] [pid 18621:tid
140352144899008] AH00489: Apache/2.4.29 (Ubuntu) mod_fcgid/2.3.9 configured
[Sat Nov 03 15:41:23.597984 2018] [core:notice] [pid 18621:tid
140352144899008] AH00094: Command line: '/usr/sbin/apache2'
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to
'/tmp/runtime-www-data'
Warning 1: Unable to find driver ECW to unload from GDAL_SKIP environment
variable.
variable.
Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP environment
variable.
variable.
variable.
Initializing server modules from "/usr/lib/qgis/server"
"Checking /usr/lib/qgis/server for native services modules"
"Loading native module /usr/lib/qgis/server/libdummy.so"
"Loading native module /usr/lib/qgis/server/libwcs.so"
"Loading native module /usr/lib/qgis/server/libwfs.so"
"Loading native module /usr/lib/qgis/server/libwms.so"
"Loading native module /usr/lib/qgis/server/libwmts.so"
Loading a file that was saved with an older version of qgis (saved in 0.0.0,
loaded in 3.4.0-Madeira). Problems may occur.
*/var/log/qgis/qgisserver.log*
22:19:45 INFO Server[4118]: Qgis Server Settings:
22:19:45 INFO Server[4118]: - QGIS_OPTIONS_PATH / '' (Override the default
path for user configuration): '' (read from DEFAULT_VALUE)
22:19:45 INFO Server[4118]: - QGIS_SERVER_PARALLEL_RENDERING /
'/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS
getMap request): 'false' (read from DEFAULT_VALUE)
22:19:45 INFO Server[4118]: - QGIS_SERVER_MAX_THREADS /
'/qgis/max_threads' (Number of threads to use when parallel rendering is
activated): '-1' (read from DEFAULT_VALUE)
22:19:45 INFO Server[4118]: - QGIS_SERVER_LOG_LEVEL / '' (Log level): '0'
(read from ENVIRONMENT_VARIABLE)
22:19:45 INFO Server[4118]: - QGIS_SERVER_LOG_FILE / '' (Log file):
'/var/log/qgis/qgisserver.log' (read from ENVIRONMENT_VARIABLE)
22:19:45 INFO Server[4118]: - QGIS_SERVER_LOG_STDERR / ''
(Activate/Deactivate logging to stderr): 'false' (read from DEFAULT_VALUE)
22:19:45 INFO Server[4118]: - QGIS_PROJECT_FILE / '' (QGIS project file):
22:19:45 INFO Server[4118]: - MAX_CACHE_LAYERS / '' (Specify the maximum
number of cached layers): '100' (read from DEFAULT_VALUE)
22:19:45 INFO Server[4118]: - QGIS_SERVER_CACHE_DIRECTORY /
'/cache/directory' (Specify the cache directory):
'//.local/share/QGIS/QGIS3/profiles/default/cache' (read from DEFAULT_VALUE)
22:19:45 INFO Server[4118]: - QGIS_SERVER_CACHE_SIZE / '/cache/size'
(Specify the cache size): '52428800' (read from DEFAULT_VALUE)
22:19:45 INFO Server[4118]: Ini file used to initialize settings:
/.local/share/QGIS/QGIS3/profiles/default/QGIS/QGIS3.ini
22:19:45 INFO Server[4118]: cacheDirectory:
/.local/share/QGIS/QGIS3/profiles/default/cache/
22:19:45 INFO Server[4118]: maximumCacheSize: 52428800
22:19:45 INFO Server[4118]: Prefix PATH: /usr
22:19:45 INFO Server[4118]: Plugin PATH: /usr/lib/qgis/plugins
22:19:45 INFO Server[4118]: PkgData PATH: /usr/share/qgis
22:19:45 INFO Server[4118]: User DB PATH:
//.local/share/QGIS/QGIS3/profiles/default/qgis.db
22:19:45 INFO Server[4118]: Auth DB PATH:
/home/ubuntu/qgis/qgisserverdb/qgis-auth.db
22:19:45 INFO Server[4118]: SVG PATHS:
/usr/share/qgis/svg////.local/share/QGIS/QGIS3/profiles/default/svg/
22:19:45 WARNING [4118]: Adding service SampleService 1.0
22:19:45 WARNING [4118]: Adding service WCS 1.0.0
22:19:45 WARNING [4118]: Adding service WFS 1.1.0
22:19:45 WARNING [4118]: Adding service WMS 1.3.0
22:19:45 WARNING [4118]: Adding service WMTS 1.0.0
22:19:45 INFO Server[4118]: Server initialized
22:19:45 INFO ../../src/server/qgsserverplugins.cpp[4118]: load library
/usr/lib/qgispython (3.4.0)
22:19:45 INFO ../../src/server/qgsserverplugins.cpp[4118]: Python support
library loaded successfully.
22:19:45 INFO Server[4118]: No server python plugins are available
22:19:45 INFO Server[4118]: ******************** New request ***************
22:19:45 INFO Server[4118]: REMOTE_ADDR: 35.180.100.12
22:19:45 INFO Server[4118]: HTTP_USER_AGENT: curl/7.58.0
22:19:45 INFO Server[4118]: Using default configuration file path:
/usr/lib/cgi-bin/admin.sld
22:19:45 WARNING [4118]: Service is not registered
22:19:45 INFO Server[4118]: Request finished in 10 ms
15:51:06 INFO Server[19726]: ******************** New request
15:51:06 INFO Server[19726]: REMOTE_ADDR: 127.0.0.1
15:51:06 INFO Server[19726]: HTTP_USER_AGENT: curl/7.58.0
SERVICE:WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/ubuntu/qgis/projects/test_qgis/milano_test.qgs
15:51:06 INFO Server[19726]: Using default configuration file path:
15:51:06 WARNING [19726]: Service
is not registered
15:51:06 INFO Server[19726]: Request finished in 0 ms
16:10:01 INFO Server[19726]: ******************** New request
16:10:01 INFO Server[19726]: REMOTE_ADDR: 127.0.0.1
16:10:01 INFO Server[19726]: HTTP_USER_AGENT: curl/7.58.0
SERVICE:WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/ubuntu/qgis/projects/qgis-server-tutorial-data/world3.qgs
16:10:01 INFO Server[19726]: Using default configuration file path:
16:10:01 WARNING [19726]: Service
is not registered
16:10:01 INFO Server[19726]: Request finished in 0 ms
16:10:04 INFO Server[19726]: ******************** New request
16:10:04 INFO Server[19726]: REMOTE_ADDR: 127.0.0.1
16:10:04 INFO Server[19726]: HTTP_USER_AGENT: curl/7.58.0
SERVICE:WMS&VERSION=1.3.0&REQUEST=GetCapabilities&map=/home/ubuntu/qgis/projects/qgis-server-tutorial-data/world.qgs
16:10:04 INFO Server[19726]: Using default configuration file path:
16:10:04 WARNING [19726]: Service
is not registered
16:10:04 INFO Server[19726]: Request finished in 0 ms
16:14:28 INFO Server[19726]: ******************** New request
16:14:28 INFO Server[19726]: REMOTE_ADDR: 127.0.0.1
16:14:28 INFO Server[19726]: HTTP_USER_AGENT: curl/7.58.0
16:14:28 INFO Server[19726]: Using default configuration file path:
16:14:28 WARNING [19726]: Service
is not registered
16:14:28 INFO Server[19726]: Request finished in 1 ms
16:15:47 INFO Server[19726]: ******************** New request
16:15:47 INFO Server[19726]: REMOTE_ADDR: 127.0.0.1
16:15:47 INFO Server[19726]: HTTP_USER_AGENT: curl/7.58.0
16:15:47 INFO Server[19726]: Using default configuration file path:
16:15:47 WARNING [19726]: Service is not registered
16:15:47 INFO Server[19726]: Request finished in 1 ms
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
