[QGIS-Developer] unable to compile release_3_4
Martin Landa
landa.martin at gmail.com
Tue Nov 6 01:25:28 PST 2018
Hi Jurgen,
út 6. 11. 2018 v 10:18 odesílatel Jürgen E. Fischer <jef at norbit.de> napsal:
> https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc11
> That will verify that the build dependencies are there and also have a cmake
> call with the parameters used for the regular build, which you can compare
> to what you use.
right,
dpkg-checkbuilddeps: error: Unmet build dependencies: libqwt-qt5-dev
python3-pyqt5.qtsql python3-pyqt5.qtsvg python3-nose2 python3-mock
python3-termcolor libosgearth-dev ninja-build
I will install packages and trigger compilation again. Thanks, Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
