[QGIS-Developer] unable to compile release_3_4
Jürgen E. Fischer
jef at norbit.de
Tue Nov 6 01:17:29 PST 2018
Hi Martin,
On Mon, 05. Nov 2018 at 23:50:10 +0100, Martin Landa wrote:
> I don't think so, 3.4.1 is a QGIS version, not Python.
https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc11
That will verify that the build dependencies are there and also have a cmake
call with the parameters used for the regular build, which you can compare
to what you use.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181106/2f827bdb/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181106/2f827bdb/attachment.ksh>
