[QGIS-Developer] QGIS 3.4.1 - GRASS 7 Folder Error Message
C Hamilton adenaculture at gmail.com
Fri Nov 9 07:42:34 PST 2018
I installed the stand alone QGIS 3.4.1 for Windows 64. If I go into the
options and click on the OK button I get the following error:
Wrong value for parameter "GRASS7 folder":
Specified path does not exist:
C:\PROGRA~1\QGIS3~1.0\apps\grass\grass-7.4.0
The version of GRASS that is installed is 7.4.2 so the variables were not
updated correctly.  In the Advanced options under Processing->Configuration
the variables GRASS7_FOLDER and GRASS_HELP_PATH are incorrect. I fixed
those, but I still get this error message. This appears to not be a part of
processing so what other variable is incorrect and how do I fix it?
Thanks,
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181109/cbcf3903/attachment.html>
More information about the QGIS-Developer mailing list
