[QGIS-Developer] QGIS 3.4.1 - GRASS 7 Folder Error Message
Nyall Dawson
nyall.dawson at gmail.com
Fri Nov 9 18:07:49 PST 2018
On Sat, 10 Nov 2018 at 01:44, C Hamilton <adenaculture at gmail.com> wrote:
> I installed the stand alone QGIS 3.4.1 for Windows 64. If I go into the options and click on the OK button I get the following error:
> Wrong value for parameter "GRASS7 folder":
> Specified path does not exist:
> C:\PROGRA~1\QGIS3~1.0\apps\grass\grass-7.4.0
> The version of GRASS that is installed is 7.4.2 so the variables were not updated correctly. In the Advanced options under Processing->Configuration the variables GRASS7_FOLDER and GRASS_HELP_PATH are incorrect. I fixed those, but I still get this error message. This appears to not be a part of processing so what other variable is incorrect and how do I fix it?
Sometimes you have to restart QGIS to get changes to the GRASS
provider settings to "stick".
This is really messy -- i'd love to see a PR which fixes this issue.
Nyall
> Thanks,
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
