[QGIS-Developer] Cannot load QGIS source code in QTCreator
Andrea Aime
andrea.aime at geo-solutions.it
Wed Nov 14 03:26:10 PST 2018
I'm trying to load the master branch of QGIS into QTCreator following the
instructions at
https://www.qgis.org/it/site/getinvolved/development/qgisdevelopersguide/qtcreator.html
Trying to load the CMakeLists.txt file fails immediately, and I get this in
the console:
Running "/usr/bin/cmake -E server --pipe=/tmp/cmake-TWdPXn/socket
--experimental" in /home/aaime/tmp/qgis-build.
CMake Project parsing failed.
Parsing of CMake project failed: Connection to CMake server lost.
I've only found this ticket searching the internet, unfortunately, it
contains no workaround:
https://bugreports.qt.io/browse/QTCREATORBUG-20972
My environment is a Linux Mint 19, which should be based on Ubuntu Bionic
(I've setup the dependencies as per docs on bionic distros).
Does anyone know of workarounds to use QTCreator?
Or, should I look at setting up using a different IDE?
Cheers
Andrea
== GeoServer Professional Services from the experts! Visit
http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
(LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181114/25c8f9b6/attachment.html>
