[QGIS-Developer] Cannot load QGIS source code in QTCreator
Tudor Barascu tudorbarascu at yahoo.com
Wed Nov 14 04:20:14 PST 2018
On Debian stretch here, I'm rarely using the QTCreator but I had no problems setting it up.Alessandro has done a nice walk-through on setting up the dev evinronment on https://www.youtube.com/watch?v=vaUVjWnm3KAMaybe that's enough for you until someone with more experience here steps up.
All the best,Tudor    On Wednesday, November 14, 2018, 1:26:26 PM GMT+2, Andrea Aime <andrea.aime at geo-solutions.it> wrote:
 Hi,I'm trying to load the master branch of QGIS into QTCreator following the instructions at https://www.qgis.org/it/site/getinvolved/development/qgisdevelopersguide/qtcreator.htmlTrying to load the CMakeLists.txt file fails immediately, and I get this in the console:
Running "/usr/bin/cmake -E server --pipe=/tmp/cmake-TWdPXn/socket --experimental" in /home/aaime/tmp/qgis-build.
CMake Project parsing failed.
Parsing of CMake project failed: Connection to CMake server lost.
I've only found this ticket searching the internet, unfortunately, it contains no workaround:
https://bugreports.qt.io/browse/QTCREATORBUG-20972
My environment is a Linux Mint 19, which should be based on Ubuntu Bionic (I've setup the dependencies as per docs on bionic distros).
Does anyone know of workarounds to use QTCreator?
Or, should I look at setting up using a different IDE?
Cheers
Andrea
==GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.==Ing. Andrea Aime @geowolfTechnical LeadGeoSolutions S.A.S.Via di Montramito 3/A55054 Massarosa (LU)phone: +39 0584 962313fax: +39 0584 1660272mob: +39 339 8844549http://www.geo-solutions.ithttp://twitter.com/geosolutions_it-------------------------------------------------------Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181114/cbddac35/attachment-0001.html>
More information about the QGIS-Developer mailing list
