[QGIS-Developer] Import in PostGIS from Processing
Raymond Nijssen
r.nijssen at terglobo.nl
Wed Nov 14 10:38:53 PST 2018
Hi Paolo,
Not sure, but is this what you mean?
algorithm name:
'Export to PostgreSQL'
description:
This algorithm imports a vector layer into a PostGIS database, creating
a new table.
Prior to this a connection between QGIS and the PostGIS database has to
be created (for example with the DB Manager).
in the dialog:
"layer to import"
It looks a bit confusing, though it depends on the view point wetter it
is an import or an export.
Regards,
Raymond
On 14-11-18 19:13, Paolo Cavallini wrote:
> Hi all,
> the Import alg in Processing is called Export in 3.4, whereas it is
> correct in 3.2 and earlier. Could someone confirm?
> Thanks.
