[QGIS-Developer] Import in PostGIS from Processing
Paolo Cavallini
cavallini at faunalia.it
Wed Nov 14 10:47:47 PST 2018
Oh, I see, you're right. Not sure it's the right semantic though, I'll have to check similar commands.
Thanks.
Il 14 novembre 2018 19:38:53 CET, Raymond Nijssen <r.nijssen at terglobo.nl> ha scritto:
>Hi Paolo,
>Not sure, but is this what you mean?
>algorithm name:
>'Export to PostgreSQL'
>description:
>This algorithm imports a vector layer into a PostGIS database, creating
>a new table.
>Prior to this a connection between QGIS and the PostGIS database has to
>be created (for example with the DB Manager).
>in the dialog:
>"layer to import"
>It looks a bit confusing, though it depends on the view point wetter it
>is an import or an export.
>Regards,
>Raymond
>On 14-11-18 19:13, Paolo Cavallini wrote:
>> Hi all,
>> the Import alg in Processing is called Export in 3.4, whereas it is
>> correct in 3.2 and earlier. Could someone confirm?
>> Thanks.
>_______________________________________________
>QGIS-Developer mailing list
>QGIS-Developer at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181114/ff3ccd15/attachment.html>
