[QGIS-Developer] Memory utilisation by Qgis
Luigi Pirelli
luipir at gmail.com
Thu Nov 22 01:17:39 PST 2018
many times crash are related to code bugs, can you be more precise?
what qgis version? a reproducible sequence of steps that generate teh crash
(if possible)
btw, the best method is to report this as issue in the issue tracker adding
all info necessary to try to replicate.
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Thu, 22 Nov 2018 at 07:42, Patrick Dunford <enzedrailmaps at gmail.com>
wrote:
> Hi
> I have some questions about how Qgis engages with the memory management
> system, specifically Linux.
> I have had a few crashes on my computer where the software crashes where
> it looks like some sort of memory limit has been reached.
> On each time I have seen the software unexpectedly crash the computer's
> physical memory was approximately three quarters used and there was no
> swap being used.
> This computer has 32 GB of RAM and 50 GB of swap. The disk that holds
> the swap is an SSD with a / partition and a swap partition, whereas
> /home is on a separate set of disks.
> I see the swap being used all the time by other applications but I have
> never seen a swap file being engaged when I am using Qgis, because it
> always would crash or show some other apparent resource-limitation
> behaviour before the physical memory was all used up and no swap was
> being used.
> Swap is used regularly by other apps on this computer, notably Gimp.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181122/029cd901/attachment.html>
