[QGIS-Developer] Geometry no showing on 3.4.1 on Windows 10, but working fine on linux or 2.18
Alexandre Neto
senhor.neto at gmail.com
Thu Nov 22 03:53:12 PST 2018
I can see now that GDAL version is different on each OS. Windows is using
2.3.2, while Linux is still at 2.2.3.
Trying to convert the file using the OGR/GDAL algorithm shows the folloing
error:
ERROR 1: Error in fread() reading object of size 232 at offset 100 from
.shp file
Alexandre Neto <senhor.neto at gmail.com> escreveu no dia quinta, 22/11/2018
às 11:19:
> Hi,
> I am having this strange error on Windows, where a layer(shapefile) will
> not show specific geometry in QGIS 3.4. Nevertheless, the same layer works
> fine on QGIS 3.4 on Linux.
> It also opens fine on windows if one uses QGIS 2.18. Saving the file in
> 2.18 (or on Linux) fixes it for QGIS 3.4 on Windows. Using the geometry
> checker, no errors were found on the geometry.
> Can this be a possble bug on Windows? Or some option that I might have
> activated?
> Here's a link for the data.
> https://www.dropbox.com/s/47grcp7i24gkley/espaco_verde.zip?dl=0
> Thanks,
> Alexandre Neto
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181122/366f36f1/attachment.html>
