[QGIS-Developer] Geometry no showing on 3.4.1 on Windows 10, but working fine on linux or 2.18
Alexandre Neto senhor.neto at gmail.com
Thu Nov 22 04:04:23 PST 2018
Since this seems related to GDAL, I am forwarding to their mailing list.
Alexandre Neto
Benjamin Ducke <benducke at fastmail.fm> escreveu no dia quinta, 22/11/2018 às
11:57:
> On 22/11/2018 12:19, Alexandre Neto wrote:
> > Hi,
> > I am having this strange error on Windows, where a layer(shapefile) will
> > not show specific geometry in QGIS 3.4. Nevertheless, the same layer
> > works fine on QGIS 3.4 on Linux.
> I have just observed the same with QGIS 2.18.25.
> Actually, I have seen this with both GeoTIFF
> and Shapefile data sources. The extent is
> correctly read from the data, the attributes and
> feature counts are also ok, but no geometries are
> visible. This does not happen with QGIS 2.18.24.
> And it also does not happen on macOS. It affects
> only some Shapefiles, but so far I fail to see
> a pattern. What I can say, is that the problem
> is not random: If a Shapefile does not display
> on a Windows machine with 2.18.25, then it will
> be the same with any other Windows machine
> running that version of QGIS.
> I can also confirm that exporting a Shapefile
> (using "Layer->Save As") from 2.18.24 (Windows)
> will make it work with 2.18.25. I suspect a
> problem with the  GDAL/OGR libs shipped with the
> latest Windows binaries.
> Best,
> Ben
> > It also opens fine on windows if one uses QGIS 2.18. Saving the file in
> > 2.18 (or on Linux) fixes it for QGIS 3.4 on Windows. Using the geometry
> > checker, no errors were found on the geometry.
> > Can this be a possble bug on Windows? Or some option that I might have
> > activated?
> > Here's a link for the data.
> > https://www.dropbox.com/s/47grcp7i24gkley/espaco_verde.zip?dl=0
> > Thanks,
> > Alexandre Neto
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Benjamin Ducke
> Deutsches Archäologisches Institut (DAI)
> Zentrale Berlin, IT-Referat
> * Projekt "Stunde Null" *
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181122/a64056ac/attachment.html>
More information about the QGIS-Developer mailing list
