[QGIS-Developer] Geometry no showing on 3.4.1 on Windows 10, but working fine on linux or 2.18
Alexandre Neto
senhor.neto at gmail.com
Thu Nov 22 04:13:48 PST 2018
The file was generated in a WEBSIG application, not sure what it uses
behind. I am pretty sure it's not GvSIG, but I will try to find what it can
be.
Thanks.
Alexandre Neto
Even Rouault <even.rouault at spatialys.com> escreveu no dia quinta,
22/11/2018 às 12:06:
> On jeudi 22 novembre 2018 11:53:12 CET Alexandre Neto wrote:
> > I can see now that GDAL version is different on each OS. Windows is using
> > 2.3.2, while Linux is still at 2.2.3.
> > Trying to convert the file using the OGR/GDAL algorithm shows the
> folloing
> > error:
> > ERROR 1: Error in fread() reading object of size 232 at offset 100 from
> > .shp file
> Looking at its
> content, I see the file size indicated in the .shp header is not correct.
> Has this shapefile been generated by an older GvSIG version ? It pretty
> much looks like the issue reported in
> https://lists.osgeo.org/pipermail/gdal-dev/2018-October/049218.html
> I've fixed a few weeks ago per
> https://github.com/OSGeo/gdal/commit/5ed09343b361b78ca5dc2fb55ec882be926e515e#diff-3bc1a345a345b6c9b580b2e412464641
> This is queued for GDAL 2.3.3
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181122/cd9e1797/attachment.html>
