[QGIS-Developer] Geometry no showing on 3.4.1 on Windows 10, but working fine on linux or 2.18
Alexandre Neto
senhor.neto at gmail.com
Thu Nov 22 06:09:24 PST 2018
Hello Even,
Is there a date for 2.3.3 release already?
Thanks,
Alexandre Neto
Alexandre Neto <senhor.neto at gmail.com> escreveu no dia quinta, 22/11/2018
às 12:13:
> The file was generated in a WEBSIG application, not sure what it uses
> behind. I am pretty sure it's not GvSIG, but I will try to find what it can
> be.
> Thanks.
> Alexandre Neto
> Even Rouault <even.rouault at spatialys.com> escreveu no dia quinta,
> 22/11/2018 às 12:06:
>> On jeudi 22 novembre 2018 11:53:12 CET Alexandre Neto wrote:
>> > I can see now that GDAL version is different on each OS. Windows is
>> using
>> > 2.3.2, while Linux is still at 2.2.3.
>> > Trying to convert the file using the OGR/GDAL algorithm shows the
>> folloing
>> > error:
>> > ERROR 1: Error in fread() reading object of size 232 at offset 100 from
>> > .shp file
>> Looking at its
>> content, I see the file size indicated in the .shp header is not correct.
>> Has this shapefile been generated by an older GvSIG version ? It pretty
>> much looks like the issue reported in
>> https://lists.osgeo.org/pipermail/gdal-dev/2018-October/049218.html
>> I've fixed a few weeks ago per
>> https://github.com/OSGeo/gdal/commit/5ed09343b361b78ca5dc2fb55ec882be926e515e#diff-3bc1a345a345b6c9b580b2e412464641
>> This is queued for GDAL 2.3.3
>> Even
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181122/154c73a9/attachment.html>
