[QGIS-Developer] Error with hdf5.dll on Windows build.
Nathan Woodrow
madmanwoo at gmail.com
Mon Oct 1 03:23:42 PDT 2018
Hey,
This is on 32bit but really I should setup a 64bit build and that might fix
the issue, plus I really should do that anyway.
For now I will just override the path in cmake like Martin said just so I
can finish this task off while I setup my 64bit build.
- Nathan
On Mon, Oct 1, 2018 at 7:42 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Nathan,
> On Mon, 01. Oct 2018 at 12:13:21 +1000, Nathan Woodrow wrote:
> > Do you have this issue with the nightly builds? Maybe something missing
> > local here?
> No, sorry. And it doesn't ring a bell.
> > > C:\OSGeo4W\bin\hdf5.dll : fatal error LNK1107: invalid or corrupt file:
> > > cannot read at 0x2B0
> Is that 32 or 64 bit? Did you perhaps install 64bit to C:\OSGeo4W?
> Looks like c:/OSGeo4W64/share/cmake/hdf5/hdf5-targets-release.cmake has
> OSGeo4W64 in it.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181001/28e5bb51/attachment.html>
