[QGIS-Developer] Error with hdf5.dll on Windows build.
Jürgen E. Fischer jef at norbit.de
Thu Oct 11 05:08:39 PDT 2018
Hi Nathan,
On Mon, 01. Oct 2018 at 20:23:42 +1000, Nathan Woodrow wrote:
> This is on 32bit but really I should setup a 64bit build and that might fix
> the issue, plus I really should do that anyway.
> For now I will just override the path in cmake like Martin said just so I
> can finish this task off while I setup my 64bit build.
I've just hit this on an old vm that still had CMake 3.7.1 - upgrading to 3.12
fixed this (but I guess 3.8 would also have been new enough).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181011/f73dd289/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181011/f73dd289/attachment.ksh>
More information about the QGIS-Developer mailing list
