[QGIS-Developer] Error with hdf5.dll on Windows build.
Nathan Woodrow madmanwoo at gmail.com
Wed Oct 24 16:55:54 PDT 2018
Thanks Jurgen.  That has fixed it.
On Thu, Oct 11, 2018 at 10:09 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Nathan,
> On Mon, 01. Oct 2018 at 20:23:42 +1000, Nathan Woodrow wrote:
> > This is on 32bit but really I should setup a 64bit build and that might
> fix
> > the issue, plus I really should do that anyway.
> > For now I will just override the path in cmake like Martin said just so I
> > can finish this task off while I setup my 64bit build.
> I've just hit this on an old vm that still had CMake 3.7.1 - upgrading to
> 3.12
> fixed this (but I guess 3.8 would also have been new enough).
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181025/e430a17d/attachment-0001.html>
More information about the QGIS-Developer mailing list
